dougrainer
Dec 15, 2016Nomad
doxiemom11 wrote:
Do you have a low and high setting on your thermostat for the fan? If so, you may want to switch it to hi. You will get a lot more air output inside.
That setting is for the Roof AC unit speed ONLY. The furnace has 1 fan motor and must turn at a specific RPM for correct combustion and air flow over the Heat Exchanger. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
