time2roll
Dec 15, 2016Nomad
IWally wrote:Seems like a lot. How large is the RV and what is the temp outside vs inside?
Is it normal to go through a 30lb tank in one day?
Hard to estimate 30 lbs in one day. Now 90 lbs in 3 days is some serious propane.
Again listen carefully to the furnace from the inside... Focus on the sounds of the burner to determine if it is cycling on-off during the heat cycle. Burner should run continuous until the thermostat is satisfied.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
