BFL13
Dec 18, 2016Explorer II
time2roll wrote:
I just want to warm some coolant and move the waste heat to the battery.
Have to modify the connecting tailpiece to have some coolant absorb the heat and then pump to the battery.
Interesting approach. The exhaust is intermittent, so storing the heat in the "coolant" would address that, but you also then have two transfers instead of one. Hmmmm.
I would have the battery bank in a "little red wagon" to get it closer to the furnace exhaust, but there are all sorts of ways to do this if you were more of a full timer in one spot long enough to make it worth the bother.
I agree the furnace noise is the greater problem. Hate it when the furnace comes on and you can't hear the TV/DVD.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
