GDS-3950BH
May 30, 2021Explorer
Firepits are low pressure and RV grills are also. Most standard grills can be adapted by removing their regulator and adding a quick disconnect fitting. You need to tap into the LPG system downstream of the regulator which is the low pressure side and install an LPG female disconnect. It's not rocket science as some would lead you to believe but does require a little common sense and some mechanical ability.
