CA_Traveler
May 30, 2021Explorer III
Good information above. Some BBQ's have a built in regulator which can be more involved to bypass which was part of my reason for installing a high pressure tap. For my setup I added the El and shut off valve, moved the regulator to the right and inserted the adapter. No cutting etc required.
Note: If you are a DIY person do not use the white teflon tape, instead buy the yellow gas type. The valve is type WOG rated for gas.
