C_Schomer
May 30, 2021Explorer
I've found that NOT all LP burners will operate on 11" w.c. I had a great rv grill about 20+ years ago that used a 15" reg/control and I tried it at 11" and it couldn't even roast a marshmallow. Plus, if you have an 11" burner and you want to skip the appliance reg/control and put your rv 11" straight to the orifice, you need a needle valve or similar, unless you want the heat to always be at high fire.
Here's what I did. I had 18 psi between the stages and that's enough to allow the use of any of the LP appliance reg/controls and retain those features, regardless of orifice pressure. I put a CGA 600 male connector on the end of the hose to connect to the disposable cylinder regs. You might need to use a high pressure extend-a-hose kit, or similar, depending on exactly what you need. Craig
