56Jeff's avatar
56Jeff
Propane hose inspection / replacement advice?
What determines when you change your propane hoses? Wait till leaks? Time driven like 4'years old? Physical inspection? Do you think wiping them down with some armorall or some rubber conditioner would help? Just wondering what the RV world experience is.
❚ Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
    Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • Putting Armor All on propane hoses is like shortening the life by half, that stuff is no good on anything.
    My rule of thumb is when I see ozone crack's in the hoses, I replace them.
  • Nothing will do more damage than AromorAll.
    I would leave them alone as far as topical products are concerned but watch for them getting petrified.
    They should last longer than 4 years - mine have lasted about ten years in the past. Then they start to leak.
    Next time I'll replace them when they get hard.
