Mako Kupo wrote:
I have a 30 pound, 40 year old ASME propane tank that I immediately removed and will be scrapping.  so, I ordered this bad boy for the rebuild.
https://www.amazon.com/gp/product/B00HTN3GSY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I'm not sure what else I need with it, I have an Atwood hot water heater(new), a gas range(have an old one, haven't looked to see if I need new yet but it looks okay), and my wave 8 furnace.  I've read the bigger the tank generally peaking, the more output pressure and the more things you can have running at once.
I would highly recommend you approach whoever you are going to get to sign off on the unit and ask THEM what they’d want to see.
It will also be better to get the inspection done before you close everything up in case you have to make changes.
