Mako_Kupo's avatar
Mako_Kupo
Propane install
hey guys! first off thanks to anyone who ha helped my rebuild so far, will be uploading pics soon, and videos not as soon. anyway, I went to do the floor today and got interrupted by rain of course, so I cleaned up and looked at what else still needed to be done.
I have a 30 pound, 40 year old ASME propane tank that I immediately removed and will be scrapping. so, I ordered this bad boy for the rebuild.
https://www.amazon.com/gp/product/B00HTN3GSY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I'm not sure what else I need with it, I have an Atwood hot water heater(new), a gas range(have an old one, haven't looked to see if I need new yet but it looks okay), and my wave 8 furnace. I've read the bigger the tank generally peaking, the more output pressure and the more things you can have running at once.
really I don't need all 3 running at once, at the max I need the furnace always dedicated for the winter(moving into this thing in like 2 months ha), and I need to be able to run either one of the other things at the same time. id love to not have to turn any switches or levers too turn one hose off, and another on, just to take my daily shower. how can I *safely* achieve this? thank you so so much you guys and gals are amazing!
  • I found something better, its the like with flare connectors built in. should I just go for those? thank goodness I don't need the rigid copper lines like the ones I pulled out I hate, hate, hate those.
  • like this?
    https://www.amazon.com/Flex-Tubing-Pipe-Fittings-Gasflex/dp/B002GV97GO/ref=sr_1_1?s=industrial&ie=UTF8&qid=1510108760&sr=1-1&keywords=copper+propane+line
    https://www.amazon.com/dp/B074QP1HGG/ref=sspa_dk_detail_0?psc=1
    https://www.amazon.com/Mr-Heater-Propane-Natural-Connector/dp/B000AMC5WY/ref=sr_1_1?s=industrial&ie=UTF8&qid=1510108836&sr=1-1&keywords=propane+line+flare+fitting
  • The trunk line should be black iron but because of all the movement, you should be using flexible copper to come off that and go to each appliance. Use flare fittings and a flaring tool not ferrules.
    Millions of RV's have been plumbed this way since the 50's and beyond.
  • My rv uses black iron pipe and then tees off to flare fittings and copper tubing. I'm hesitant about giving any more advice other than if you aren't sure, ask a plumber...
  • I don't want to have to use a brass line, will this do? thanks!
    https://www.amazon.com/gp/product/B0024E6TX2/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
  • You would need a regulator and then to run a gas pipe from the regulator and tee off to each appliance. They should all be connected, no need to unhook one to use the other.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
