Mini_Pig's avatar
Mini_Pig
Propane Line capping?
Hi. I recently bought a used truck camper. It had a fridge and a stove. The fridge did not work, but as far as I can tell, the stove does. I removed the fridge, but now I have an open propane line. I know I can just run a single line now and that's the ultimate goal.
But in the mean time, can I use a ball valve water line shut off to cap the old line to the old fridge?
By cutting the nut part off and putting the ball valve fitting on the end. Which would in theory work. My thought is, if the ball valve can stop water, would it stop propane?
  • philh's avatar
    philh
    Explorer III
    Valve by itself is not legal... it still needs a plug installed.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Standard fitting hardware will have the plug you need. Any hardware. IF you still have it take the solenoid valve from the fridge. Else measure the nut's opening
  • Ivylog wrote:
    You can buy a male copper plug that goes into the nut on the end of the line at H Depot.
    This is the easiest/cheapest and BEST way to cap off a LP line. Doug
    PS, BRASS, not copper:B
  • Yup, looks like this. It’s in the plumbing section with all the other brass fittings.
  • Ivylog's avatar
    Ivylog
    Explorer III
  • I would use a proper gas fitting that caps the existing threaded end fitting.
    Or if needed attach the proper compression fitting to attach the cap.
    I would not attach a valve. Especially one made for water.
  • LPG **** valves are affordable and proven. They usually have a twist dial-like wheel on the side. Is a trip to the hardware store a burden?
Having RV issues? Connect with others who have been in your shoes.24,347 PostsLatest Activity: Jan 10, 2026
