setlifrd's avatar
setlifrd
Propane line replacement
I have a Four Winds Travel Trailer. The hose from the tanks (regulator) to the pipe mounted on the chassis has developed a leak. I have looked at the hose and connectors and compared them to those listed online. Most of what I find are for tank to grill. Can anyone point me in the right direction to find the correct hose.
Thanks in advance for the advice.
Don
  • Thank you! It is so obvious to take the old hose in for the replacement. I guess the brain was not working after having one of those days at work.
    Thanks for the replies.
  • Almost any CO-op or Propane bulk dealer should have what you are needing, you are going from the steel pipe to the gas regulator correct? I know Our local propane dealer can make the hose you need just take the old one in and they can copy it.
