dougrainer
Dec 13, 2013Nomad
whiteeye42 wrote:
Before they came out with the new 80% valves they use to fill to 100% and nobody complained then they started replacing with the new valves and everybody started complaining that they were getting ripped off since they were only getting 80% that extra 1/2 gallon won't hurt a thing just run the heater and the fridge for an hour and you will be good to go
NOT TRUE at all. LP has always been filled to 80%. The CORRECT way to fill is NOT by the 80% valve spewing but by WEIGHT only. You can fill any type DOT cylinder in any position and if done correctly by WEIGHT, the tank will have the normal correct fill. IGNORANT LP fillers fill by spewing 80% valves. If the OP's tank was overfilled in sub 30 degree temps and never bled off, when he reached the higher 70 degree and up, the odds are the tank would have safety vented. VERY DANGEROUS to have this happen. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
