westend
Dec 16, 2013Explorer
RJsfishin wrote:The fill valve is built to allow the displaced air to exit the tank slowly. The over-pressure relief valve opens instantaneously and it is not slow. When they open there is a release of liquid propane and is it not a small release.
I don't understand the tanks blowing up. All the valves are designed to vent slowly. Tanks cannot blow up if the valves are operating properly.
We had a bad event close to me a few years ago at the local farm co-op. A customer brought a 100 lb.. cylinder to be filled. Within moments of starting the fill, the tank exploded, killing the young guy filling the tank. The shrapnel from the explosion ruptured a nearby bulk tank and nearly burned the building to the ground. A couple of others were also injured.
The cause of the tank exploding was later found to be that the cylinder had acetylene in it at some point and the acetylene residue combined with the introduction of propane caused a reaction.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
