I'm going to replace the pigtail on my propane tank. I know some folks like to use a type of goop, some use the white Teflon "plumbers tape," while others use a specific type of Teflon tape made spec...
You can safely use the white teflon tape. The yellow is just thicker and is designed for use with the coarse, heavy duty steel pipes used for natural gas. The white is likely to work better than the yellow for the pigtail fittings.
