salem's avatar
salem
Propane Pigtail
I'm going to replace the pigtail on my propane tank. I know some folks like to use a type of goop, some use the white Teflon "plumbers tape," while others use a specific type of Teflon tape made specifically for gas. Looking for advice on which is better, if any. Thanks.
  • time2roll wrote:
    NONE. Should have an inverted flair on regulator end and O-ring seal on the tank side.
    Dope and tape are for tapered pipe threads only.
    BTW I recommend Cavagna brand pigtail for a superior crimp on the hose.
    The OP is replacing the pigtail. The side at the regulator will require a sealant.
  • NONE. Should have an inverted flair on regulator end and O-ring seal on the tank side.
  • Neither one is "better". They will both work for that job.
  • Use the yellow gas tape or the sealant goop both available at any hardware store.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 15, 2025
