Almot's avatar
Almot
Explorer III
Apr 09, 2014
Propane plumbing - adding cat heater
Will install Platinum Cat heater, trying to figure out what fittings I need. With trailer being in Mexico, it's easier to bring all the parts from the US or Canada.
3/8 OD copper pipe going from under-floor iron pipe to gas range and other appliances is a nominal 1/4 ID, right?
So here is how I see it - for above the floor section. Correct me if I'm wrong:
1) 1/4 ID copper pipe exits the floor inside and will have 1/4 compression x 1/2 FPT- with compression going onto the copper pipe.
2) 1/2 FPT of part #1 goes onto the 1/2 MIP of 1/2 MIP x 1/2 MIP stainless 24" gas appliance connector - with excess flow valve included, it works like a shut-off valve. I could've just run the 1/4" pipe all the way to heater, but this 24" connector will make routing easier, and it has a valve.
Corrosion Q:
On brass compression fittings Home Depot has a warning "not to use on stainless tubing". I know about corrosion of dissimilar metals - is this really a problem? This warning is on compression only. That gas appliance connector is stainless, with brass excess valve - and there is no warning. Also, black iron pipes below, exposed to elements, have brass Tees where 1/4 copper pipe is connected - and they didn't see it as a problem. So there is no problem with stainless connector?
3) 1/2 MIP end of the connector #2 goes into the FIP end of 1/2x3/8 FIP coupling.
3/8 FIP end (NOT flared) goes onto 3/8 male flared end of the heater. I couldn't find a coupling 1/2 FIP x 3/8 female flared - is this a problem?
Not being a gas fitter I could've missed something - maybe a lot. Any criticism is appreciated. In a small Mex town it's better to understand what needs to be done and how, even if you hire somebody.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
