Gas stove stopped working. Still plenty of propane. Using auxiliary tank due to long stay in one spot. Talked to RV repairmen. Replaced regulator. Now stove works but just barely. Any suggestions? ...
If the stove on a slide out check the propane hose under the slide. It could be crimped. I had that problem once. If not then it might be the regulator on the stove.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
