ajriding's avatar
ajriding
Explorer II
Mar 11, 2019
Propane Regulator - BBQ style
What is the difference between the two-stage RV regulator with the big vent and the Homedepot ones with no big vent?
They are the same 11WC, so is the big vent critical? I think it locks the valve closed when no propane is being used, maybe the BBQ style does not???
Can I use BBQ one in RV?
  • one is for indoor use and the other is for outdoor, this not rocket science.
  • Old-Biscuit wrote:
    ajriding wrote:
    So, for just running one thing at a time the cheap one is fine? But more demand will cause freeze up.It's al about preventing frost..
    NO!
    The biggest thing I do is heat water, and that is quite a flame, but do not usually do much else - maybe cook on the stove at the same time, or possibly run the heater in cold weather. I think the fridge is insignificant.
    What I need is best solved with the style of BBQ ones, the RV store has configurations that complicate things.
    NO!
    Yes, big vent, little vent. The BBQ ones just have the little vent (tiny hole)
    The correct regulator for your RV is the 2 Stage Regulator NOT the BBQ single stage one.
    Use the correct regulator vs trying to reinvent the wheel.
    You guys cant agree among yourselves…
    Yes, my needs are best served by the configuration that the BBQ one has, none of the RV ones are quite right. Of course this is not talking about vents, just the configuration of tube, regulator, fittings placement…
    If readers do not mind, I am really looking for the reasons, not the regulation or what you have. BBQ uses one type, RV the other. One guy says it is because of higher volume of flow to prevent freezing, the other disagrees but offers no support for reasoning. It is safe for a BBQ grill, what makes an RV so much more volatile?
    NO!
    NO!
  • 2 stage regulation is required by RVIA which adopts NFPA 1192
  • So, for just running one thing at a time the cheap one is fine? But more demand will cause freeze up.It's al about preventing frost..
  • Capacity- at a high volume load, evaporating that much lp in one step makes it freeze up, whereas going from cylinder pressure to 10-20 psi, then down to the 11” we prevents that, as well as giving better regulation.
    And they do have a vent, it’s just a hole, not a large vent. That hole could get blocked easily as well.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
