rrunner's avatar
rrunner
Propane Regulator Frozen?
We had some rather cold weather here recently (below freezing)and when I went to check the RV furnace it wouldn't fire. I checked the regulator and the gauge of green/red triangles was showing indicating no fuel. My tanks had propane so I took them inside for a couple of days but same result. I poured boiling water over the regulator but again nothing. Stove won't work either. Nothing is getting past the regulator ! Any suggestions?
❚ Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
Having RV issues? Connect with others who have been in your shoes.24,332 PostsLatest Activity: Nov 05, 2025
