time2roll
Jan 17, 2016Nomad
sgrol wrote:The switching regulator is two stage and will handle 30 psi or 100 psi just fine on each side with no effect on operation.
Still doesn't make sense. The unregulated tank is 12" from switching regulator and it's pressure is not decreased prior to entry to the switching regulator. In other words, far tank is regulated and enters switching regulator at 30 psi. Close tank is not regulated and enters switching regulator at tank pressure (around 100 psi depending on temp).
Safety calls for no longer than 5' hose at full tank pressure so what is the issue?
If you want a 30 psi regulator on both that is fine but redundant.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
