ken56
Jan 07, 2017Explorer
At only 14 months old that furnace should be fine but you never know. Do you have any idea how many times that furnace has been used? It takes quite a while to get the oils to burn off a new furnace heat exchanger. It will produce an acrid offensive smell that will burn the eyes and nose and be most unpleasant. All I can suggest is run your furnace as much as you can when you aren't in it and see if it clears up. Ours took about 2 tanks of propane to clear it up. I am able to keep my unit at home so I ran it in the winter when we were not using it. It did finally go away.
