John_Joey
Jan 07, 2017Explorer
You could have a cracked heat exchanger, something I wouldn't play around with. Nothing worst then waking up dead. On that topic I would buy a carbon monoxide detector and plug it in.
Since you got the unit out you can bench test it pretty easy. All you need is a 12 volt battery and a propane line. Take it outside and hook it up and see if you can spot what the problem is. Go to YouTube to see how to bench test it.
