rhagfo
Jan 07, 2017Explorer III
TakingThe5th wrote:
I hope you don't have a hole in your heat exchanger.
X2!
Could be a manufacturing defect in the heat exchanger!
Not likely from the exhaust as the combustion chamber is using and exhausting to outside air, the heated air is strictly recycled inside air. The only way for the two to mix is bad heat exchanger.
