John_Joey
Jan 08, 2017Explorer
time2roll wrote:trailrider wrote:+1SwanInWA wrote:That most certainly is it! That connection at the gas valve only has propane pressure when the furnace is burning.
We found the gas line running to the igniter to be ridiculously loose, so we tightened it up. Could that be it I wonder? Still planning a bench test and a smoke test. Thanks a BUNCH for all of your suggestions. I'll let you know.
Reinstall and test.
x2, but I would bench test first if you can before reinstall. I would still get a carbon monoxide detector. They are fairly cheap but do only run on 110v.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
