azdryheat
Dec 15, 2013Explorer
The gas regulator valve may be the culprit and preventing gas flow. The gas pressure on both sides of the valve needs to be equalized. Turn off the gas tank valve(s, disconnect the gas line(s) at the tank(s) and then turn on one of the stove burners but don't try to light it. This will equalize the air pressure on both sides of the gas regulator. Finally turn the stove burner off, reconnect the gas line(s) and turn the tank(s) valve(s) back on. This procedure will get the regulator back on-line and get the gas flowing again.
