gkainz
Dec 16, 2013Explorer
Someone posted above to have the tanks filled. Not quite necessary at this point to troubleshoot. Take the tank(s) out, weigh them on a bathroom scale. Find the TARE weight stamped on the top of the tank and subtract that from the total weight. Remaining is how many pounds of propane you have.
Assuming you have "some", replace the bottles, reconnect the regulator and hoses and slowly open one or both bottles.
If you have an automatic changeover valve, point the handle towards the heaviest/fullest bottle. You should have a green indicator on the changeover valve, if installed.
Continue troubleshooting as noted above - especially the shutoff valve on the stove. Typically, (if not otherwise marked) the valve handle indicates ON if in-line (parallel) with the gas line and OFF if perpendicular with the gas line.
Troubleshoot in a methodical, logical flow.
Start at the tank. Do I have propane?
Open the valve slowly.
Is automatic switchover valve installed/working/set?
Follow the gas flow to first place you do or do not have gas.
