Old-Biscuit
Dec 16, 2013Explorer III
OP has a Class C so probably has a small 'tank' mounted vs removable cylinders.
Wires cut on LP Detector....no power to tank solenoid valve....no propane flow.
Low battery voltage (beep, beep)
Twist LP Detector wires together....check battery voltage...check solenoid valve opening....light off stove top burners.
Need to get propane flowing before any other gas appliances will work
