katysdad
Dec 17, 2013Explorer
The three wires from detector: White is normally the ground in rv's
green or black is most likely 12v check with a test light. If no voltage check fuses.
the remaining wire should go to the valve at the propane tank. As a test you can hook the 12v feed to the wire going to the solonoid valve.
Propane detectors will beep if batteries are low as a warning.
If it is the brown detctor, if it is still working, can take several minutes to warm up and send power to the solonoid. Light should be steady green and no beeping when at this stage.
Solonoid valve itself could be bad.
If it is the original detector, it should have been replaced ten years ago. they have a seven year life span.
If you find the problem is the detector or valve, replace them as a unit don't mix and match.
You can disconnect the hose at the regulator and solonoid to check for gas flow
from each component until you find out where it stops flowing to make it easier
to check.
Check any connections with soapy water when finished to make sure there are no leaks.
to check.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
