Rmack1ExplorerJul 04, 2017Propane tank gaugeI saw a propane tank gauge for three bucks that looks like a strip of tape that goes on the outside of the tank. Do these things work?
time2rollNomadJul 04, 2017While in use or heavy use only as the strip works on temperature.Yes hot water should get you a reading.If you have two tanks it is probably better to just watch the automatic regulator.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentGauge For Propane TanksPropane Tank Gauge,recomendations pleaseNear engine overheating gaugePropane Tank GaugePropane gauges on tanks question
