tempforce
Oct 03, 2013Explorer
try changing the hoses from the tank to the regulator. (longer hoses)...
also i installed a 't' fitting where the hose from the regulator to the black pipe connects.
on the un-used fitting i installed a cap… a couple times a year when full timing. i would shut off the propane. remove the cap at the 't' and drain oil from the lines.
this helps prevent gas lines freezing and cuts down on flow harmonics…..
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
