AZCeltic's avatar
AZCeltic
Propane tank pigtails
My trailers propane tank came equipped with a pigtail that has a 1/2" male fitting connected to the tank regulator, which is also 1/2". The hose has developed a slow leak at one end. I purchased a new pigtail at Camping World, but it has a 1/4" male end on it. I have been trying to find a coupler/reducer for this, but have had no luck. Any suggestions??
  • AZCeltic wrote:
    Your replies are much appreciated. I already have the CW pigtail with the 1/4" IMF. My problem is the female connection on the regulator is not 1/4", but 1/2". I need some sort of size reducer.
    I replaced my hoses Saturday & my old rubber hoses had the adapter on them so just unscrewed & reused.
  • beemerphile1 wrote:
    Any neighborhood hardware store can fix you up with a brass adapter. It might require two, a 1/2ip x 1/4ip bushing and then a 1/4ip x inverted flare adapter.
    ^^^^This.^^^^ Even our local Home Depot has the adapters you would need.
  • What is make and model of your regulator?
    Sounds like a multi-stage with a tee on the bottom and not a switch over.
  • How old is the regulator? Consider just replacing it.
    Cavagna on Amazon
    Or do you have something special to run a large generator or something else big on propane?
  • Any neighborhood hardware store can fix you up with a brass adapter. It might require two, a 1/2ip x 1/4ip bushing and then a 1/4ip x inverted flare adapter.
  • Your replies are much appreciated. I already have the CW pigtail with the 1/4" IMF. My problem is the female connection on the regulator is not 1/4", but 1/2". I need some sort of size reducer.
Having RV issues? Connect with others who have been in your shoes.24,359 PostsLatest Activity: Feb 06, 2026
