Dutch_12078
May 31, 2014Explorer III
NorCal Dan wrote:
Why do you suppose they placed restrictions on DOT propane tanks and not ASME tanks?
ASME tanks are built to much tougher specifications than DOT cylinders. The tank walls are thicker and the fill port is heavier duty than the combined service valve/fill port on DOT cylinders. ASME tanks also had OPD's long before DOT cylinders were required to have them. ASME tanks are also built for permanent installation, so they don't get the stress placed on them that DOT cylinders can see riding around in the back of trucks, etc.
