DiskDoctr wrote:
dpgllg wrote:
The 30lb tanks in my 5th wheel need to be recertified or replaced. I have tried to locate a place that does recertification near me in SW PA but no luck. The propane suppliers don't offer the service and cannot recommend a place.
Does anyone have a suggestion on where to look or is it just better to buy two new tanks?
Thanks!
Dave
Hi Dave.
Dale Oxygen $5 per tank, all over.
Amerigas Delmont. Call ahead to their office
Just had mine done at Dale Oxygen. Less than $50 for both 30lbs filled and recertified.
Thanks for the information. Did they stamp a new date on the bottle neck? I have found that some just visually check and do not stamp new date.
I have found a local welding place that will perform a visual inspection and if OK will fill them. My bottles are clean and no rust as they are in inside compartments on my 5th wheel.
