SaltiDawg
Jun 18, 2013Explorer
jstorta15 wrote:
I turned the bleeder screw a little and propane came out immediately so I think that confirms there is no air that needed to be purged.
I don't believe that this is a valid conclusion. When you have a lot of air in an LP tank and crack the bleeder you will always get a stream of a mixture of air and propane.
Generally on a backyard gas grill, the amount of air in the tank will not be obvious in that the burner will usually heat up just fine. That said, if using the tank to power a generator it will be very obvious.
That said, the symptoms you are describing do not suggest air in the tank to me.
Can you borrow a 20# tank from a neighbor and see if that works?
Best of luck.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
