HappyKayakers
Feb 08, 2023Explorer III
I've had a couple of valves get stuck like that on #20 cylinders. I could never get them unstuck and cylinder replacement would cost about the same as valve replacement. The last time I was lucky and the valve was open just enough to finish using the tank before I trashed it.
agesilaus wrote:
If the good wrong way advice does not work, then the valve can be replaced. Call around to find a local propane shop that services tanks.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
