Grit_dog
Feb 10, 2023Trailblazer
groundhogy wrote:
I tried turning the valve either way and its stuck solid.
Hard to understand as it is such a soft turn normally.
Also, i thought, what if i disconnect hose and try to turn the knob...
The propane comes whooshing out. Its stuck open even without the hose.
Normally the propane doesnt come out until an official hose is connected, right?
You’re correct. That valve is fubarred.
There’s a safety valve that doesn’t allow LP to flow if there’s no restriction downstream IE if it’s not hooked up to something that holds pressure.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
