groundhogy's avatar
groundhogy
Propane tank valve - stuck solid
We are traveling. Just made it passed Atlanta west and at Newborn truck stop on Rt 20.
(Laid back, private owned, $10 showers, restaurant looks real good)
Wife closed off the valve this morning.
I go to open it just now, and i am NOT STRONG ENOUGH! Lol.
I call her out to try and turns out shes not strong enough either.
I got out the channel locks, no go (although you can’t get a good grip on these three point knobs). I got scared to really gorilla the knob.
Any ideas?
  • If the good wrong way advice does not work, then the valve can be replaced. Call around to find a local propane shop that services tanks.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    TenOC wrote:
    Are you sure it is OFF and not ON. Try to turn it off before turning it on.
    c
    Likely the best advice.. Try turning it the other way.
    And you can get a good grip on the knob but ... Not the way you think.
    Turn pliars 90 degrees. attack from top.
  • Are you sure it is OFF and not ON. Try to turn it off before turning it on.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
