Mont_G_J
Jan 05, 2014Explorer
Are you sure the tank is empty? I find it puzzling that the tank could be empty if the valve is stuck shut.
Is it remotely possible you have a situation like below?
AmeriGas: Troubleshooting Your Propane Cylinder
www.amerigas.com/exchange/consumer/connect.htm?
Connect Your Propane Cylinder. With today's propane cylinder safety valves, propane will no longer flow out of a cylinder simply by opening the hand wheel.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
