Old-Biscuit
Oct 09, 2015Explorer III
Typically it is the RED Regulator (Single Stage 30# failure) that causes problems......then the pigtail hose secondary suspect (Excess Flow Valve in ACME Nut failure)
Having replaced those two components, already swapping cylinders from one side to other and SLOWLY OPENING Cylinder service valve (CORRECT??)
then only thing left (and they do fail) is the high pressure hose that goes across from roadside to curbside
