Norcold 1200? Not sure of your Frig has been Recall or not. Might want to check your exact serial number Unit you have.
From Norcold website:
If you have one of these refrigerator models, use the following procedure:
1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
4. Call your dealer immediately.
http://www.norcoldrecall.com/Good Luck
