time2roll
Mar 17, 2017Nomad
westend wrote:I disagree. Parking pawl is not designed to keep the vehicle from rolling.
You are talking about the parking brake? The foot actuated brake cable that is used for parking? My suggestion is to never use it, not even when parked. There is all kind of likelihood that using it will result in problems.
Parking brake should be used anytime the car would roll in neutral.
If you don't trust it then it needs to be fixed.
To the OP: I think you are on the correct track. Keep watch for a bit after any adjustment as the mechanical connection can change a bit after proper forces are applied.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
