MEXICOWANDERER
Aug 15, 2018Explorer
JaxDad
Did you pick the lock to my place and uncloak the BORG? I stripped a 4/0 THHN cable to get the 12 gauge solid strands. They soldered right to the Megawatt terminal strip. All three feeders are paralleled each polarity. It's a lot of work doing that to the two units.
ANYTHING YOURS WILL DO
MY BORG WILL DO BETTER
Online 24/7 for SEVEN YEARS
Try having a battery fully charged in float mode then loading it with 35 amps
What happens?
Mine stays in float varying not a tenth of a volt while the charger is supplying 35 amps.
Consumers have been trained whip and chair to be satisfied with inadequate garbage. "It sez smart and that's as good as it getz"
What happens?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
