Cadillac_Jack's avatar
Oct 16, 2014
Proper Wiring for two controllers to one battery bank
Ok guys here is what I have, and what I want to do.
I have two 120 watt panels running through a 10 year old PWM charge controller to a set of two group 27 deep cycle 12 volt Trojans.
I also have the original 50 watt panel that came with the camper siting unplugged.
I just purchased the Rouge 2024 MPPT controller. I am going to run the 120 watt panels through the Rouge controller to the group 27s.
So now I have the original 50 watt panel along with original PWM controller. I want to wire this up to the same battery bank. My questions are in regards to proper wiring.
Do I run the wires from both controllers straight to the battery?
Or do I run the wires from both controllers through a set of 12 volt circuit breakers then run them separately to the battery?
Or do I run the wires from both controllers through a set of 12 volt breakers then join the wires together then to the battery ?
Maybe I need to fuse the leads and don't need the breakers at all?
Thanks for any thoughts from the experts.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
