landyacht318
Feb 16, 2016Explorer
1.2825 or there abouts.
Make sure no bubbles stick to float. Lesser states of charge seem to have more bubbles stick to float.
Make sure glass tube is mostly vertical with minimal contact between float and glass sides.
If checking while charging, note that inner cells will be warmer than outer cells and temperature compensate accordingly.
Give the thermometer a while to respond to the electrolyte temperature, and cool ambient temps will throw off readings.
If the battery has not moved and not been charged for a while, the electrolyte can be stratified, with the dense acid on the bottom. This will throw off readings. So some agitation, or holding it at gassing voltages should mix it up for a more accurate reading.
Quick, get a charging source on that poor battery or I will report you for batterycide!! :)
