NinerBikes
Feb 17, 2016Explorer
SCVJeff wrote:
I know I'll get cr@p from the battery crowd here, but this "unclear" line has bothered me for years both on battery hydrometers, as well as the one I use floating in my salt reef tanks. There is friction glass to glass in the hydrometer tube as well as water creep on the probe, and the same water "creep" on my floating tank probe. In the tank I can look at it from below the water line and above and interpret two different readings.
In the salt tank I cured this issue with a Refractometer. For the batteries I just bought a HydroVolt and used it on my T-145's over the weekend. It tracks my glass tube hydrometer exactly without the tapping of bubbles and rattling around to zero out the glass on glass friction with a repeatable reading. It's simply a better mouse trap and no glass to break. Read the full .PDF sheet on it.
This is a small benefit to AGM batteries. No burnt acid hole in your clothes, no opening up, and pulling out the trays supported to check the readings on the two batteries in the back, no tearing apart all the cable connections and losing the copper washers or lock washers, and no corrosion forming on any of your copper connector cables, no matter how nicely they are hand made and sealed up.
And you don't have to lift them half or 1/4 or 1/8 as often, those gut buster lead slugs. :S :B Let me know if you need a hand, don't be afraid to ask, if you need help.
