SCVJeff
Feb 18, 2016Explorer
MEXICOWANDERER wrote:Dunno what the difference is, but Magnum swapped it out once already as I was bumping up against the transformer foldback temp. The 1st one they were convinced that the varnish dip had air bubbles around the windings and causing heat problems. This one is WAY better and doesn't dip into failsafe, but it still gets hot
The "lost" amp hour capacity in an absorbed glass mat battery is exactly why the battery can survive "100%" discharges, resist freezing while barely having a charge and a a whole host of other attributes that separates the battery from flooded lead acid batteries. I had the old Trace 2500SB charging at it's maximum rated 120-amperes at 12-volts plenty of times without smelling like Mount Krakatoa. I wonder what's different about the Magnum?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
