otrfun
Dec 13, 2017Explorer II
Thanks for the replies.
Didn't realize our new Jayco came standard with a Progressive Dynamics Intellipower power panel with a 60 amp converter and Charge Wizard button built in! Our last 3 TT's came with WFCO's, so I naturally assumed our new Jayco would come with one, too.
Looks like we'll only need an inverter since we can easily get into bulk mode with the Charge Wizard button. The only problem is the converter is located at the very rear of a 30+ ft. TT. There's no way we'll get anywhere near 60 amps of charge current with that long of a run. Will probably parallel this run with another cable to increase charge current.
Guess all we need now is a 1000-1500 watt PSW inverter. Looks like a lot of reasonably priced ones available. Had real good luck with a 600 watt PSW Powerbright in our last trailer. May go with another Powerbright.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
