wopachop's avatar
wopachop
Pull batts in the summer?--1a draw good for batts w/ solar?
I was reading threads here and came across advice that its good to cycle a deep cycle battery once a month? My trailer has (2) 12v batteries and a solar panel that keeps them topped off, regardless of having my battery shut off switch turned off. Is that good or bad? Keep meaning to buy a disconnect for that positive solar wire to make it easy.
Worried this might become super long and confusing. Let me lay out the situation with numbers.
1. 99% of the time i use the the trailer its plugged into shore power.
2. The trailer has solar panels and there is no disconnect between the solar and batteries.
3. I go out of town for weeks and unplug the trailer and also sometimes the solar charging wire.
4. (here comes the root of the question) I installed a fan that pulls 1amp. I want this fan to turn off and on several times a day using a 12v digital timer while im gone.
So that leads to these questions:
1. Should i power the 1amp fan from the main batteries and let the solar keep them charged? Then do a real cycle on the batts once a month or whatever is recommended?
2. Since the trailer is 99% shore power should i pull the batteries out and put them in the cooler garage? Power the 1amp fan from a small independent solar panel? (will actually be set to 0.25amps so a small 10w panel should power it i hope. no digital timer the sunrise and sunset will be the timer)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
