azrving
Aug 03, 2014Explorer
You may get even better performance from it if you need a wire upgrade. Mine was 6 gauge and it went from the converter at the curb side to the drivers side, towards the rear about 8 feet and then back to the curb side 8 feet to the battery box. I shortened it up by going down the curb side with number 4 gauge. It lost about .5 in voltage drop. The lug on the converter is made to accept 4 gauge but you can use 2 gauge and knock another 2/100 or so off the voltage drop. 2 gauge wont fit in the lug but some have mentioned that they make an adapter that would make it work. That may be splitting hairs but I would surely run 4 gauge from the converter to the batteries. If you have a newer rig you may already have it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
