pianotuna
Aug 01, 2020Nomad III
wapiticountry wrote:MEXICOWANDERER wrote:50 amp service does not demand copper conductors. Modern parks are most often wired with 4/0 4/0 4/0 direct burial aluminum with a #2 aluminum ground in a loop feed. (Note that the neutral is not allowed to be undersized in RV park applications). That is up to current code and works just fine.
If at home
Go outside
Look at the gauge of cable servicing your drop. 100 or 200 amps AL.
50 Amos demands 6AWG CU. conductor.
It is a mere distance between your transformer and your service drop. Now look at how an RV Park is wired (shudder)
Mex was point out that #6 copper is the minimum size. Of course, Aluminum may be used--but requires larger than #6
Hell's bells why not use gold? *grin*
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
